Overview of the Installation and Configuration Process for
HA for Oracle Database
The following task maps summarize the tasks for installing and configuring
HA for Oracle Database. The tables also provide cross-references to detailed
instructions for performing the tasks.
Perform these tasks in the order that they are listed. If you are using
HA for Oracle Database with Oracle Data Guard, perform these tasks on each cluster where your
Oracle Database instances are running.
Note -
Single instance Oracle ASM is not supported in an Oracle Solaris Cluster
4.3 configuration.
Table 1 Task Map: Installing and Configuring HA for Oracle Database
Plan the HA for Oracle Database installation and configuration
Prepare the Oracle Solaris Cluster nodes and disks
Install the Oracle Database software
Verify the Oracle Database installation
Create an Oracle database
Set up Oracle Database permissions
Install the HA for Oracle Database packages
Register and configure HA for Oracle Database
Verify the HA for Oracle Database installation
Tune the HA for Oracle Database fault monitor
(Optional) Customize the HA for Oracle Database server fault monitor
(Optional) Upgrade HA for Oracle Database resource types
(Optional) Change the role of an Oracle Data Guard instance
Table 2 Task Map: Installing and Configuring HA for Oracle Database with Clustered
Oracle ASM Instances
Install Oracle Grid Infrastructure software
Install Oracle Database software
Verify Oracle Database installation
