This chapter describes the steps to install and configure Oracle Solaris Cluster HA for Network File System (NFS) (HA for NFS) on your Oracle Solaris Cluster nodes.
You must configure HA for NFS as a failover data service. See Chapter 1, Planning for Oracle Solaris Cluster Data Services, in Oracle Solaris Cluster 4.3 Data Services Planning and Administration Guide and the Oracle Solaris Cluster 4.3 Concepts Guide document for general information about data services, resource groups, resources, and other related topics.
The NFS mount points that are placed under the control of the data service must be the same on all of the nodes that can master the disk device group that contains those file systems.
HA for NFS requires that all NFS client mounts be “hard” mounts.
No Oracle Solaris Cluster node may be an NFS client of a file system that is exported by HA for NFS and is being mastered on a node in the same cluster. Such cross-mounting of HA for NFS is prohibited. Use the cluster file system to share files among cluster nodes.
If Oracle Solaris Resource Manager is used to manage system resources allocated to NFS on a cluster, all HA for NFS resources which can fail over to a common cluster node must have the same Oracle Solaris Resource Manager project ID. This project ID is set with the Resource_project_name resource property.
