Siebel Business Process Framework: Workflow Guide > Using Predefined Workflow Policies > Using Predefined Workflow Policy Programs for Siebel Marketing >
Using a Workflow Policy Program to Create Activities for a Marketing Campaign
The Create Campaign Contact Activity workflow policy program creates an activity for the contacts or prospects who are the targets of the campaign. To define the data that Siebel CRM uses to update the Contact Activity record, you use the Workflow Policy Program Arguments list. Table 53 describes some of values that you can assign.
Table 53. Arguments for the Create Campaign Contact Activity Workflow Policy Program
Name |
The following values are available:
- Description. Use text to describe activity.
- Status. Choose the activity status, such as planned or active, from the drop-down list.
- Type. Choose the Activity type from the drop-down list.
Required |
Indicates if the argument is required. |
Value |
Text or drop-down list. |
