| Siebel CRM Siebel Mobile Guide: Disconnected Siebel Innovation Pack 2014 Rev. A E52427-01 |
![]() Previous |
![]() Next |
View PDF |
You can run a saved predefined query (if available) for some Siebel objects in Siebel Mobile, as shown in the following procedure.
Note : This task is not supported in offline mode. |
To run a predefined query in Siebel Mobile
Tap the Side Menu icon on the application banner and then select an object from the drop-down list.
Tap the PDQ drop-down list (shown in Figure 8-1) on the application banner to display the list of saved predefined queries for the object.
Scroll up and down the predefined query list that opens to find the query that you want to run.
Tap a predefined query in the list.
This step runs the predefined query, returning the appropriate data in the list view.
Tap PDQ on the application banner again to close the predefined query.
