| Siebel Customer Relationship Management Siebel Fundamentals for Siebel Open UI Siebel Innovation Pack 2014 E52425-01 |
![]() Previous |
![]() Next |
View PDF |
Screens contain sets of information in views. These views display data in different formats. For example, you can sometimes view the same data in an explorer view, in a chart, or in a list. You access these views by clicking the second level view bar. The second level view bar is immediately below the application toolbar, on the left side of the screen. Figure 3-3 shows an example of the second level view bar with a list of available views.
The active view appears in a different color in the view list. In Figure 3-3, the active view is Account List. If the view you want to use is not visible, then use the scroll down arrow on the right side of the list to display and select that view.
You can configure your Siebel application to show screens and views in tab format at the top of your screen or in tree format on the left side of your screen. For more information, see "Setting Navigation Options".
