| Siebel Customer Relationship Management Siebel Fundamentals for Siebel Open UI Siebel Innovation Pack 2014 E52425-01 |
![]() Previous |
![]() Next |
View PDF |
By default, the Siebel Open UI client uses the Side Menu icon as the navigation control. There are two other options available for navigation control settings: tab and tree. For more information about the Side Menu, see "About the Side Menu".
If you select the tab format for navigation settings, the screen tabs and associated link bars appear near the top of your screen.
If you are left-handed, then you can set the names for the screen tabs and associated link bars to appear on the left side of the screen so that you can more easily access this information. In this scenario, these names appear in tree format and not in tab format and link bar format.
To set navigation options
From the application-level menu, choose Tools, then User Preferences.
The User Preferences screen appears.
On the link bar, click Behavior.
The Behavior form appears.
Select the desired value from the drop-down list for the Navigation Control field.
