| Siebel Customer Relationship Management Siebel Fundamentals for Siebel Open UI Siebel Innovation Pack 2014 E52425-01 |
![]() Previous |
![]() Next |
View PDF |
The Siebel Open UI client uses transition effects when you navigate between different screens and views. You can configure your preferred type of transition effect.
Note: Transition effects are limited in some deployments of the Siebel Open UI client. For more information about the transition effects available to you, contact your Siebel administrator. |
To set the transition effects
From the application-level menu, choose Tools, then User Preferences.
The User Preferences screen appears.
On the link bar, click Behavior.
The Behavior form appears.
From the drop-down list for the Transition field, choose from the available options.
