| Siebel Customer Relationship Management Siebel Fundamentals for Siebel Open UI Siebel Innovation Pack 2014 E52425-01 |
![]() Previous |
![]() Next |
View PDF |
When tile applets appear in the Siebel Open UI client, scroll arrows appear on either side of the tiles. For example, tiles appear in the Contact List view of the Contacts screen after you click the Tile button. You can configure the scroll speed for tile applets. The scroll speed is the speed at which the tiles move when you click a scroll arrow.
You can set the scroll speeds for all tile applets.
To set the default scroll speed for all tile applets
From the application-level menu, choose Tools, then User Preferences.
The User Preferences screen appears.
On the link bar, click Behavior.
The Behavior form appears.
Select a value from the drop-down list for the Default Scroll Speed field.
You can set the Scroll speed for a specific tile applet. For a specific tile applet, the scroll speed that you set overrides the scroll speed that you set for all tile applets.
To set the scroll speed for a specific tile applet
Navigate to a view that displays a tile applet.
At the bottom right side of the tiles, adjust the slide bar to control the scroll speed.
Note: The number representing the scroll speed appears to the right of the slide bar. |
The scroll speed is modified for the tile applet.
