| Siebel Customer Relationship Management Siebel Fundamentals for Siebel Open UI Siebel Innovation Pack 2014 E52425-01 |
![]() Previous |
![]() Next |
View PDF |
You can designate the color that appears for the following elements in the user interface:
Some active buttons.
Link names in fields.
Background colors.
To set the color for user interface elements
From the application-level menu, choose Tools, then User Preferences.
The User Preferences screen appears.
On the link bar, click Behavior.
The Behavior form appears.
Select color value from the drop-down list for the Theme field.
Note: You cannot select a value in the Theme field if the Navigation Control field has no value. |
