| Siebel Customer Relationship Management Siebel Fundamentals for Siebel Open UI Siebel Innovation Pack 2014 E52425-01 |
![]() Previous |
![]() Next |
View PDF |
The quick print function can use the print feature in your browser to print the records that currently appear in a list. For more information, see "Printing Records".
To set quick print options
From the application-level menu, choose Tools, then User Preferences.
The User Preferences screen appears.
On the link bar, click Printing.
The Printing form appears.
Complete the fields as needed to set up printing the way you want it.
Some fields are described in the following table.
| Field | Description |
| Application Menu - Print Behavior | Select from the following options to determine how screen data prints when you use the application-level menu (File, then Print):
This field applies only to HTML. If you use Microsoft Excel, only the list is printed. |
| Applet Menu - Print Behavior | Select from the following options to determine how screen data prints when you use the menu button (Menu, then Print):
| Print Individual Lists Using | Select from the following options:
| Rows to Print | Select from the following options to determine how you want rows to print:
| Columns to Print | Select from the following options to determine how you want columns to print:
