| Siebel Customer Relationship Management Siebel Fundamentals for Siebel Open UI Siebel Innovation Pack 2014 E52425-01 |
![]() Previous |
![]() Next |
View PDF |
You can print records in the Siebel application in the following ways:
Running a report. You can print records by running and then printing a report. For more information about reports, see "Running Reports".
Browser print. You can use the print feature for the browser to print an image of the current screen. If you want to print a screen that contains colors, then you can use the color printing feature for your browser. Color printing is important for screens in which colors signify meaning, such as calendar screens and notification screens.
Note: The printed output might not be an exact replica of what you see on your screen. The print options for your browser determine the printed output. |
Quick Print button. You can use the quick print functionality that works through the print feature for the browser. Browser print (HTML) allows you to print both lists and forms.
You can print records by using quick print.
To print records by using quick print
Navigate to the list that contains the records you want to print.
Click the Quick Print button on the application toolbar.
The print settings in your user preferences determine quick print options. For more information about setting up quick print options in your user preferences, see "Setting Quick Print Options".
Use the print feature in the browser to send the output to your printer.
