| Siebel Customer Relationship Management Siebel Fundamentals for Siebel Open UI Siebel Innovation Pack 2014 E52425-01 |
![]() Previous |
![]() Next |
View PDF |
In the Siebel clients (Siebel Web Client, Siebel Mobile Web Client, and Siebel Developer Web Client), you run Siebel Reports in views. While in a view, you can perform a query, and then select the report you want to run. For more information, see Chapter 7, "Locating Information Using Query and iHelp."
You can monitor long-running reports, view previously run reports, and delete reports. For more information about the Siebel Reports user interface, see Siebel Reports Guide.
Note: Reports functionality is an optional extension to Siebel Business Applications. |
To run a report
Navigate to the screen and view that contains the information for which you want to run a report.
(Optional) Limit report data by running a query.
On the application toolbar, click the Reports button.
The Run Report pane appears.
In the Run Report pane, complete the appropriate fields.
Some fields are described in the following table.
| Field | Description |
| Report Name | Select an available report. The available reports apply to the screen and view to which you navigate. |
| Custom Name | Type a custom name for the report if you want to name the report a different name from the value in the Report Name field. |
| Output Type | Select the output type for the report. |
| Report Locale | Select the locale for the report. |
Click Submit.
The designated report runs.
Click My Reports to navigate to the Reports view of the BI Publisher Reports screen.
A record for the run report appears in the Reports view.
Drill down on the Report Name field in the Reports view to display the report in a new window.
You can print the report by using the print feature for the application in which it appears.
