| Siebel Customer Relationship Management Siebel Fundamentals for Siebel Open UI Siebel Innovation Pack 2014 E52425-01 |
![]() Previous |
![]() Next |
View PDF |
You can access the query control by clicking the magnifying glass icon on the menu toolbar. For more information about the magnifying glass icon and the menu toolbar see "About the Menu Toolbar".
Within the query control, you access the Find drop-down list, which helps you narrow the your query criteria. Figure 3-13 shows an example of the query control, with Contacts selected in the Find drop-down menu.
