| Siebel Customer Relationship Management Siebel Fundamentals for Siebel Open UI Siebel Innovation Pack 2014 E52425-01 |
![]() Previous |
![]() Next |
View PDF |
You can select saved queries from the drop-down list for the Saved Queries field in the top right corner of the application window. In this list, you can access your saved queries and the predefined queries established by your organization. Figure 3-10 shows an example of the drop-down list for the Saved Queries field in the Menu Toolbar. For more information about saved queries, see Chapter 7, "Locating Information Using Query and iHelp."
