| Siebel Customer Relationship Management Siebel Fundamentals for Siebel Open UI Siebel Innovation Pack 2014 E52425-01 |
![]() Previous |
![]() Next |
View PDF |
Use the controls that appear in the top right corner of each list and form to change the layout of the home page for your Siebel application. The changes you make to the layout using these controls remain in effect until you change the layout again. Table 12-1 describes these controls.
Table 12-1 Home Page Controls
| Option | Description |
Hides the list or form and temporarily removes it from the home page. You must edit the layout of the home page to place the list or form back on the home page. |
Collapses the list or form to its minimal size showing no records. |
Expands the list or form to its standard size. |
