| Siebel Customer Relationship Management Siebel Fundamentals for Siebel Open UI Siebel Innovation Pack 2014 E52425-01 |
![]() Previous |
![]() Next |
View PDF |
The edit layout function lets you access more advanced layout editing functions, such as showing hidden lists or forms, collapsing or expanding all the available lists and forms at once, and restoring the default layout. You can use the edit layout function to edit both the home page for your Siebel application and screen home pages. The changes you make remain in effect until you change the layout again.
To edit the layout of a home page
At the home page, click Edit Layout.
In the Edit Layout form, click the controls to change each list or form that appears.
The controls are described in the following table.
| Control | Description |
Collapses the list or form to its minimal size showing no records. |
Expands the list or form to its standard size. |
Moves the list or form up on the page to reposition it above other lists and forms on the page. |
Moves the list or form down on the page to reposition it below other lists and forms on the page. |
Hides the list or form in the home page. |
Shows a previously hidden list or form and places it back on the home page. |
To apply the same action to all forms and lists at the same time, click the menu button, and then click an option.
The options are described in the following table.
| Option | Description |
| Hide All Applets | Removes all lists and forms from the home page, and the home page is blank. |
| Show All Applets | Places all the lists and forms back on the home page. |
| Collapse All | Collapses all lists and forms on the home page. |
| Expand All | Expands all lists and forms on the home page. |
To restore the default layout for the home page, click Default Layout.
Click Done.
The home page appears in the layout you define.
