| Siebel Customer Relationship Management Siebel Fundamentals for Siebel Open UI Siebel Innovation Pack 2014 E52425-01 |
![]() Previous |
![]() Next |
View PDF |
Table 14-5 lists the keyboard shortcuts you can use when performing record management tasks.
Table 14-5 Record Management Keyboard Shortcuts
| Action | Keyboard Shortcut | Context |
Create a new record. |
CTRL+ALT+N CTRL+N |
List, form |
Create a new record using a Quick Fill template. |
CTRL+K |
Form |
Create a new record using the last used Quick Fill template. |
CTRL+J |
Form |
Apply a Quick Fill template to a record. |
CTRL+Q |
Form |
Copy a record. |
CTRL+ALT+C CTRL+B |
Record |
Save a record. |
CTRL+SHIFT+S CTRL+S |
List, form |
Delete a record. |
CTRL+ALT+D CTRL+D |
Record |
Undo a record. |
CTRL+ALT+U CTRL+U ESC |
Record |
Select all records. |
CTRL+ALT+A (The preceding shortcut applies when each record appears with a check box.) CTRL+A |
List |
