| Siebel Customer Relationship Management Siebel Fundamentals for Siebel Open UI Siebel Innovation Pack 2014 E52425-01 |
![]() Previous |
![]() Next |
View PDF |
Table 14-6 lists the keyboard shortcuts you can use to navigate to records in the Siebel application.
Table 14-6 Record Navigation Keyboard Shortcuts
| Action | Keyboard Shortcut | Context |
Go to the previous record. |
CTRL+SHIFT+, (comma) CTRL+UP ARROW ALT+, (comma) |
List, form |
Go to the next record. |
CTRL+SHIFT+. (period) CTRL+DOWN ARROW ALT+. (period) |
List, form |
Go to the previous record set. |
CTRL+ALT+, (comma) |
List |
Go to the next record set. |
CTRL+ALT+. (period) |
List |
Go to the first record set. |
CTRL+ALT+F ALT+F |
List, form |
Go to the last record set. |
CTRL+ALT+L ALT+L |
List, form |
