| Siebel Customer Relationship Management Siebel Fundamentals for Siebel Open UI Siebel Innovation Pack 2014 E52425-01 |
![]() Previous |
![]() Next |
View PDF |
Table 14-7 lists the keyboard shortcuts you can use to work with queries.
Table 14-7 Query Management Keyboard Shortcuts
| Action | Keyboard Shortcut | Context |
Create a new query. |
CTRL+ALT+Q ALT+Q |
List, form |
Run a query. |
CTRL+ALT+ENTER ALT+ENTER CTRL+ENTER |
List, form |
Refine a query. |
CTRL+ALT+R ALT+R ALT+G |
List, form |
Save a query with different name. |
CTRL+ALT+S ALT+S |
List, form |
Open a dialog box for the query assistant. |
CTRL+SHIFT+Z |
List, form |
Cancel a query. |
CTRL+SHIFT+9 |
List, form |
