| Siebel Customer Relationship Management Siebel Fundamentals for Siebel Open UI Siebel Innovation Pack 2014 E52425-01 |
![]() Previous |
![]() Next |
View PDF |
Table 14-10 lists the keyboard shortcuts you can use to work with the calculator control.
Table 14-10 Calculator Control Keyboard Shortcuts
| Action | Keyboard Shortcut | Context |
Click the BS (Backspace) button. |
BACKSPACE |
Calculator control |
Click the CE (Clear Entry) button. |
HOME |
Click the CA (Clear All) button. |
END |
Click the Use button. |
ENTER |
Click the Erase button. |
DELETE |
Close the calculator control without saving data. |
ESC |
