| Siebel Customer Relationship Management Siebel Fundamentals for Siebel Open UI Siebel Innovation Pack 2014 E52425-01 |
![]() Previous |
![]() Next |
View PDF |
Table 14-11 lists the keyboard shortcuts you can use to share information with others.
Table 14-11 Communication Management Keyboard Shortcuts
| Action | Keyboard Shortcut | Context |
Go to the Correspondence screen to send a letter. |
CTRL+SHIFT+L CTRL+L |
Record |
Open a dialog box to send an email. |
CTRL+ALT+1 F9 |
Record |
Open a dialog box to send a fax. |
CTRL+ALT+2 CTRL+F9 |
Record |
Open a dialog box to send a page. |
CTRL+ALT+3 SHIFT+F9 |
Record |
Open a dialog box to send an outbound wireless message. |
CTRL+ALT+4 ALT+F9 |
Record |
