| Siebel Customer Relationship Management Siebel Fundamentals for Siebel Open UI Siebel Innovation Pack 2014 E52425-01 |
![]() Previous |
![]() Next |
View PDF |
You might find that you want to cancel your changes to a record before you save the record. You can undo your changes to a record only if you have not yet saved the record.
Note: You cannot undo your changes or additions in selection dialog boxes. For example, when you add or remove employees from a selection dialog box, you cannot undo those changes. |
To cancel changes to a record in form or a list
Click the menu button, and then click Undo Record.
Note: Alternatively, press the Esc key to cancel changes to a record. The Esc key is only supported for a single undo operation. Pressing the Esc key multiple times may result in unexpected behavior depending on the user interface element or the control used. |
