| Siebel Customer Relationship Management Siebel Fundamentals for Siebel Open UI Siebel Innovation Pack 2014 E52425-01 |
![]() Previous |
![]() Next |
View PDF |
You can delete a record by using the Delete button, the menu button in a list or form, and the application-level menu.
Employee records are end-dated but not deleted to preserve historical information. For example, if an employee creates 100 records and later leaves the organization, then those records are not deleted in the Siebel application.
Note: When a parent record is deleted, explicitly or by using a merge, the primary ID fields are not immediately updated. For performance reasons, the primary ID fields are updated only when the parent record is required, and a refresh of the screen is performed. |
You can delete a record using the Delete button.
To delete a record using the Delete button
Select the record you want to delete.
In a list, the selected record is highlighted.
Click Delete.
A dialog box appears, asking you to confirm the deletion.
Click OK to delete the record.
You can delete a record using the menu button.
To delete a record using the menu button
Click the menu button, and then click Delete Record.
You can delete a record using the application-level menu.
To delete a record using the application-level menu
From the application-level menu, choose Edit, then Delete Record.
