| Siebel Customer Relationship Management Siebel Fundamentals for Siebel Open UI Siebel Innovation Pack 2014 E52425-01 |
![]() Previous |
![]() Next |
View PDF |
Calendar views are available in screens, such as Accounts, Contacts, Campaigns, Projects, and Opportunities. Each Calendar view allows you to create activities without navigating to the Calendar screen and leaving the current screen.
Calendar views in screens allow you to associate activities with an active record. For example, if you create a new activity in the Calendar view of the Accounts screen, then the new activity appears with the Account and Site fields populated from the active account record.
You can navigate to a date in Calendar views in the following ways:
Select values in the date value fields at the top of the view, and click Go.
Click the Today button to navigate to the current date when the current date does not appear in the displayed calendar.
This date navigation is available only if administrators configure calendar views in screens for the Siebel Open UI client. For more information this configuration, see Configuring Siebel Open UI.
