| Siebel Customer Relationship Management Siebel Fundamentals for Siebel Open UI Siebel Innovation Pack 2014 E52425-01 |
![]() Previous |
![]() Next |
View PDF |
When you create a recurring activity, the Repeat Until field defaults to a predetermined value that is based on the value you select from the drop-down list for the Repeat Frequency field. You can change this predetermined value as needed.
Table 11-4 shows the default values for the Repeat Until field. For more information about creating recurring activities, see "Creating Recurring Calendar Activities".
