| Siebel Customer Relationship Management Siebel Fundamentals for Siebel Open UI Siebel Innovation Pack 2014 E52425-01 |
![]() Previous |
![]() Next |
View PDF |
Note the following points when you work with calendar activities:
Selecting a value in the Repeat Frequency field automatically sets a value in the Repeat Until field and determines that the activity is recurring.
The date and time in the Start field cannot be later than the date and time in the End field.
If you select the Alarm check box in the Calendar Detail form of a calendar activity, and you select the Done check box in the Activity form of that calendar activity, then the Alarm check box is cleared.
