| Siebel Customer Relationship Management Siebel Fundamentals for Siebel Open UI Siebel Innovation Pack 2014 E52425-01 |
![]() Previous |
![]() Next |
View PDF |
You can refine the criteria of a predefined query or a user-defined query.
Note: If you refine the criteria of a predefined query, then you must save the query with a different name to save the query. |
To refine a saved query
Navigate to the screen.
From the drop-down list for the Saved Queries field, select the query.
The records meeting the query criteria appear.
Do one of the following:
In a list or form, click the menu button, and then click Refine Query.
From the application-level menu, choose Query, then Refine Query.
Use the appropriate keyboard shortcut.
Add and edit the criteria.
In the list or form, click the menu button, and then click Run Query.
From the application-level menu, choose Query, then Run Query.
The query executes, and the records that match the criteria appear.
