| Siebel Customer Relationship Management Siebel Fundamentals for Siebel Open UI Siebel Innovation Pack 2014 E52425-01 |
![]() Previous |
![]() Next |
View PDF |
You can delete user-defined queries.
To delete a saved query
Navigate to the screen.
From the application-level menu, choose Query, then Delete Saved Query.
The Delete Record dialog box appears, showing the user-defined queries for that screen.
Select the query you want to delete in the Query Name list.
Click OK to delete the query.
