| Siebel CRM Fundamentals Siebel Innovation Pack 2014 E24770-01 |
![]() Previous |
![]() Next |
View PDF |
A text field allows you to type text directly into the field. You can click in the field and begin typing. Figure 3-2 shows an example of a text field; Figure 3-3 shows an example of a text field with a text editor button.
You can launch a text editor from a text field in a list or form to create, edit, or view large amounts of text. This editor can be accessed by clicking the text editor button in the top right corner of the text field. In a list, this button appears only after the text field has been selected. Figure 3-4 shows an example of the Siebel Text Editor that appears when you click the text editor button.
When you click the text editor button in a read-only field, a text reader appears. In this case, you cannot make changes to the text.
