| Siebel CRM Fundamentals Siebel Innovation Pack 2014 E24770-01 |
![]() Previous |
![]() Next |
View PDF |
You use the calendar control, shown in Figure 3-10, to select date and time information for a field. You access the calendar control by clicking the calendar select button in any date or time field. Table 3-3 describes each element of the calendar control.
Table 3-3 Description of Calendar Control Elements
| Element | Description |
Month and Year |
Shows the month and year. Use the left and right arrows to navigate to the previous and next month in sequence. Use the drop-down arrow next to the month to select a different month, and use the drop-down arrow next to the year to select a different year. |
Calendar |
Shows the calendar for the month. Use the calendar to select a date by clicking the date in the calendar. |
Time field |
Lets you define the time. You can use the spin control in the field to change the time, or you can type a value. This field appears only if you access the calendar control for a field that requires a time. |
Time zone drop-down list |
Lets you select a time zone. This field appears only if you access the calendar control for a field that requires a time. |
Save button |
Lets you save your selections. You can also click outside of the control to save your selections. |
Cancel button |
Lets you cancel your selections and leave the field blank or left with the values it contained before you accessed the calendar control. |
