| Siebel CRM Fundamentals Siebel Innovation Pack 2014 E24770-01 |
![]() Previous |
![]() Next |
View PDF |
The Siebel application toolbar appears below the application-level menu. The left part of the toolbar, shown in Figure 4-2, provides access to frequently used tools such as the Site Map. You use the right part of the toolbar, shown in Figure 4-3, to find information in your Siebel application. The tools available on the application toolbar are described in Table 4-1.
Table 4-1 Application Toolbar Controls
| Control | Name | Description | Related Topic |
Displays the Site Map. |
Activates the Search Center, which allows you to search for and find records. |
Enables you to access iHelp. iHelp provides guidance with tasks. |
Activates a task UI wizard to guide you through a series of steps to complete a specific task. |
Lets you print the data you are currently viewing. (Depending on your user preferences, this button might be grayed-out.) |
Lets you access reports for the screen you are working in. |
Provides access to your saved queries and to the predefined queries established by your organization. |
Using Query to Locate Information |
Launches a new query. |
Executes a query after you have defined query criteria. |
