| Siebel CRM Fundamentals Siebel Innovation Pack 2014 E24770-01 |
![]() Previous |
![]() Next |
View PDF |
The application is organized into screens. Each screen covers a broad topic. You access a screen by clicking the related screen tab, such as Opportunities, Calendar, or Accounts, or by using the Site Map.
An active screen tab appears in a different color. Figure 4-5 shows an example of screen tabs, where Contacts is the active screen tab. You can specify which screen tabs are displayed in your Siebel application.
You can change the screen tab icons in Siebel Tools. Contact your Siebel administrator if you do not want to display icons on the screen tabs.
Related Topics
