| Siebel CRM Fundamentals Siebel Innovation Pack 2014 E24770-01 |
![]() Previous |
![]() Next |
View PDF |
Screens contain sets of information shown in views. These views display data in different formats. For example, you can sometimes view the same data in a list, in an explorer view, or in a chart.
You access views by clicking a hyperlink on the link bar, shown in Figure 4-9 for the Administration-Application screen. In the link bar, the active view appears in bold text (Branch Locator in Figure 4-9). The link bar appears immediately below the screen tabs. If the view you need is not visible, click the down arrow at the end of the list to display and select another view (the down arrow appears to the right of the Business Service Access hyperlink on the link bar in Figure 4-9). When you select another view, the last hyperlink on the link bar is replaced with the selected view.
Related Topic
