| Siebel CRM Fundamentals Siebel Innovation Pack 2014 E24770-01 |
![]() Previous |
![]() Next |
View PDF |
The buttons described in Table 4-5 appear at the top of lists and forms. In addition to these buttons, your Siebel application might contain additional buttons or other elements on each list and form.
Table 4-5 Common Buttons in Lists and Forms
| Button | Description |
The menu button provides access to a menu of actions that apply to the active form, list, or explorer view, or a selected record in a list. Using the options in the menu, you can perform actions such as copy, edit, delete, and advanced sorting. Note: If you right-click in a form or a list you can access the same menu of actions provided by the menu button in that form or list. |
New |
Lets you create a new record. In a list, clicking this button inserts a new, empty row at the top of the list so you can create a new record. In a form, clicking this button displays a form with empty fields that you can fill in to create a new record. |
Delete |
Lets you delete the selected record. |
Query |
Lets you define and launch a query in a form or list. For more information about querying, see Chapter 8, "Using Query to Locate Information." |
