| Siebel CRM Fundamentals Siebel Innovation Pack 2014 E24770-01 |
![]() Previous |
![]() Next |
View PDF |
If you are using Internet Explorer, you must make sure your Internet options are set up properly to allow for correct calendar printing.
To set Internet Explorer options for Calendar printing
Start Internet Explorer.
Choose Tools, then Internet Options.
The Internet Options dialog box appears.
Click the Advanced tab.
Under Printing, select the Print background colors and images check box.
Click OK.
Related Topic
