| Siebel CRM Fundamentals Siebel Innovation Pack 2014 E24770-01 |
![]() Previous |
![]() Next |
View PDF |
You can delete a record by using the Delete button, the menu button in a list or form, the application-level menu, or the appropriate keyboard shortcut. For more information about keyboard shortcuts, see Chapter 15, "Using Keyboard Shortcuts."
Employee records are end-dated but not deleted in order to preserve historical information. For example, if an employee creates 100 records and later leaves the organization, the Siebel application does not delete those records.
Note: When a parent record is deleted, explicitly or using a merge, the primary ID fields are not immediately updated. For performance reasons, the primary ID fields are updated only when the parent record is required, and a refresh of the screen is performed. |
You can delete a record using the Delete button.
To delete a record using the Delete button
Select the record you want to delete.
In a list, the selected record is highlighted, and a blue border appears around the list or the form that contains the selected record.
Click Delete.
A dialog box appears, asking you to confirm the deletion.
Click OK to delete the record.
You can delete a record using the menu button.
To delete a record using the menu button
Click the menu button, and then click Delete Record.
You can delete a record using the application-level menu.
To delete a record using the application-level menu
From the application-level menu, choose Edit, then Delete Record.
