| Siebel CRM Fundamentals Siebel Innovation Pack 2014 E24770-01 |
![]() Previous |
![]() Next |
View PDF |
Using the Saved Queries tab in the User Preferences screen, you can perform a query on existing saved queries that you saved previously. For more information on queries, see Chapter 8, "Using Query to Locate Information"
To view a saved query
From the application-level menu, choose Tools, then User Preferences.
The User Preferences screen appears.
On the link bar, click Saved Queries.
The Saved Queries list appears.
