| Siebel CRM Fundamentals Siebel Innovation Pack 2014 E24770-01 |
![]() Previous |
![]() Next |
View PDF |
Once you have created quick fill templates, you can change some of their properties, and you can deactivate or delete the templates.
You can only perform the tasks provided in this topic for quick fill templates you created.
To rename a quick fill template
From the application-level menu, choose Tools, then User Preferences.
The User Preferences screen appears.
On the link bar, click Quick Fill Templates.
The Templates list appears.
Select the template you want to rename.
In the Template Name field, type a new name for the quick fill template.
(Optional) In the Description field, make your changes.
You can deactivate a quick fill template.
To deactivate a quick fill template
Select the template you want to deactivate.
In the Active field, clear the check box and save your changes.
The template is no longer available for selection when you create a new record from a quick fill template.
You can reactivate a quick fill template.
To reactivate a quick fill template
Select the template you want to reactivate.
In the Active field, select the empty check box and save your changes.
The template is now available for selection when you create a new record from a quick fill template.
You can permanently delete a quick fill template.
To permanently delete a quick fill template
In the Templates list, select the quick fill template you want to delete and click Delete.
At the confirmation dialog box, click OK.
In the standard Siebel application Quick Fill Templates menu options are available for some applets such as Activity Form Applet and are not available for other applets, for example, FS Invoice Form Applet. It is possible to assign the Quick Fill Template menu options to other applets by adding Applet Method Menu Item objects.
To add Applet Method Menu Item objects to a quick fill template
In Siebel Tools, select the applet to which you want to add the quick fill template options.
Add a new Applet Method Menu Item to the applet.
The Applet Method Menu Item defines a menu item in the applet-level menu for the parent Applet object definition.
Add the following values:
Command: ApplyTemplate
Menu Text: Apply Template
Command: SaveTemplate
Menu Text: Save as Template
Command: NewFromTemplate
Menu Text: New From Template
Command: NewFromLastTemplate
Menu Text: New From Last Template
For more information about the Applet Method Menu Item, contact your Siebel administrator.
