| Siebel CRM Fundamentals Siebel Innovation Pack 2014 E24770-01 |
![]() Previous |
![]() Next |
View PDF |
You can send email messages, faxes, pages, and wireless messages from within your Siebel application. The record that is active when the Send command is executed determines what information will be sent and what options are available. The following commands are available on the application-level File menu:
Send Email. Allows you to send email directly from your Siebel application.
Send Fax. Allows you to send a fax directly from your Siebel application.
Send Page. Allows you to page someone directly from your Siebel application.
Send Wireless Message. Allows you to send a message to another person's wireless device from your Siebel application.
You might not have access to send functionality, depending on the configuration of your application. Contact your Siebel administrator for details.
Sending a fax, page, or wireless message is similar to sending an email. Choose the appropriate Send command from the application-level File menu. If you cannot send a fax, page, or wireless message, contact your Siebel administrator.
Related Topic
"Using the Send Email Command"
"Setting Outbound Communications Preferences for Send Email"
Using the Send Email command, you can send email messages from any context within your Siebel application. Depending on how the Siebel administrator has configured the application, you can use context-specific email message templates to improve efficiency and standardize replies for types of communications that occur frequently. Figure 11-1, "Example of Send Email Dialog Box" provides an example of the Send Email dialog box.
Your Siebel application supports individual user choice regarding the software used for Send Email. The choice of software is determined by the value of the Email Client user preference setting in your Siebel application.
To send an email from your Siebel application
Navigate to the desired screen.
Select the record from which you want to send the email.
Depending on the view you are in, data associated with the record might be inserted into the email.
From the application-level menu, choose File, then Send Email.
The Send Email dialog box appears.
Note: The Pick Recipients dialog box might appear, depending on the screen you are in when you invoke the Send Email command. If it does, select a recipient from the list (you can select None) and click OK. |
Verify that the From field includes your profile name. If it does not, select a profile name from the From drop-down list. If no profile is available, contact your Siebel administrator.
Fill in the appropriate fields. You can select a template containing predefined text for the email from the Body drop-down list.
(Optional) Attach literature and other files to the email by clicking either the add literature or add attachment button (highlighted in step 3). Launching the email from an attachment record automatically attaches the file to the email.
Note: If you attach multiple documents to the email (either literature items or documents), only the last item you attached appears in the Attachments field. To see a list of all attached items, click the add attachment button. |
(Optional) If you selected HTML as your Default Message Format user preference, you can edit aspects of the message text such as font size, font color, paragraph justification, and so on. This formatting will be visible to the email recipient if the recipient's email client software supports HTML.
(Optional) Click Check Spelling to run a spell check on the text of the email.
Click Send to send the email.
Related Topics
