| Siebel CRM Fundamentals Siebel Innovation Pack 2014 E24770-01 |
![]() Previous |
![]() Next |
View PDF |
You can create your own queries and save them in the Queries drop-down list for later use. Queries that you create are called user-defined queries. They allow you to enter your own criteria to locate a specific set of records.
To create, execute, and save a new query
Navigate to the desired screen.
Do one of the following:
In the list or form, click Query.
In the list or form, click the menu button, and then click New Query.
Click the new query button on the toolbar.
In a list or form, right-click and choose New Query.
From the application-level menu, choose Query, then New Query.
Use the appropriate keyboard shortcut.
Depending on where you are when you invoke the new query command, a blank form or a blank row in a list appears.
Enter the query criteria in the appropriate fields.
In the list or form, click Go.
In the list or form, click the menu button, and then click Run Query.
Click the execute query button on the toolbar.
In a list or form, right-click and choose Run Query.
From the application-level menu, choose Query, then Run Query.
The query executes and the matching records appear.
From the application-level menu, choose Query, then Save Query As.
The Save Query As dialog box appears.
In the Query Name field, enter a name for the query and click OK.
The saved query now appears in the Queries drop-down list.
