| Siebel CRM Fundamentals Siebel Innovation Pack 2014 E24770-01 |
![]() Previous |
![]() Next |
View PDF |
After clicking Query in a form or list, you can click Query Assistant to launch a dialog box that will guide you through creating a query. The Query Assistant button appears to the right of the Cancel button after you click Query. The Query Assistant dialog box can be helpful if you do not want to add your own query operators or are not familiar with query operators. When you use the Query Assistant, you do not have to enter operators to find the information you are looking for. You can also save your query by clicking Save Query before you execute the query. The query assistant example shown in Figure 8-1 is querying for all accounts in which the value in the City field is San Francisco and the value in the Potential Volume field exceeds $10,000. Querying in the Query Assistant is case-insensitive.
Note: It is not possible to use EXISTS in the Query Assistant for MVG fields. |
To perform a query using the Query Assistant
Navigate to the desired screen.
In the list or form, click Query.
Depending on where you are when you invoke the new query command, a blank form or a blank row in a list appears.
Click Query Assistant.
The Query Assistant appears.
In the first row, from the Select Field drop-down list, choose a field to query on.
In the first row, from the drop-down list to the right of the field you just selected, choose an operator for the query.
In the first row, in the field to the right of the operator you just selected, enter the value you want to query for.
Fill in other rows as desired.
From the Perform Query using drop-down list, select AND or OR to specify the type of operator you want to use between your criteria.
AND will only show results that meet all the criteria. OR will show results that meet any of the criteria.
Click Go.
The query executes, the Query Assistant closes, and matching records appear.
Note: If there are no values in the Query Assistant's drop-down lists, contact your Siebel administrator. |
