| Siebel CRM Fundamentals Siebel Innovation Pack 2014 E24770-01 |
![]() Previous |
![]() Next |
View PDF |
There are two buttons, shown in Table 7-1, that launch selection dialog boxes: the single select button and the multiple select button.
Table 7-1 Description of Select Buttons
| Button | Name | Description |
Single select button |
Launches a single selection dialog box. |
Multiple select button |
Launches a shuttle dialog box. |
Single selection dialog boxes. Single selection dialog boxes allow you to add a maximum of one record to a field. In some cases you can create a new record from the single selection dialog box.
Shuttle dialog boxes. Shuttle dialog boxes allow you to select a number of records and add them to a field. An example of a shuttle dialog box is shown in Figure 7-1, "Example of Shuttle Dialog Box".
Note: To select records in selection dialog boxes you can double-click, press ENTER, or click OK. |
