Siebel Object Interfaces Reference > COM Data Control Quick Reference > Object Interfaces Reference >
Business Component Methods for COM Data Control
Table 143 describes a summary of business component methods you can use with COM Data Control. It does not include object interface methods that Siebel CRM does not call directly from a business component instance. For information about methods that Siebel CRM calls with the InvokeMethod method on a business component, see Business Component Invoke Methods.
Table 143. Summary of Business Component Methods for COM Data Control
Method
Description
Format
ActivateField Method for a Business Component
Activates a field.
Dim busComp as SiebelBusComp
BusComp.ActivateField(fieldName as String)
ActivateMultipleFields Method for a Business Component
Activates multiple fields.
busComp.ActivateMultipleFields(oPropSet as SiebelPropertySet)
Associate Method for a Business Component
Creates a new many-to-many relationship for the parent object through an association business component.
busComp.Associate(whereIndicator as Integer)
BusObject Method for a Business Component
Returns the name of the business object that the business component references.
Dim busObject as SiebelBusObject
Set busObject = busComp.BusObject
ClearToQuery Method for a Business Component
Clears the current query but does not clear sort specifications on a business component.
busComp.ClearToQuery
DeactivateFields Method for a Business Component
Deactivates the fields that are currently active from the SQL query statement of a business component.
busComp.DeactivateFields
DeleteRecord Method for a Business Component
Removes the current record from a business component.
busComp.DeleteRecord
ExecuteQuery Method for a Business Component
Returns a set of business component records.
Dim buscomp as SiebelBusComp
buscomp.ExecuteQuery(cursorMode As Integer) As Boolean
ExecuteQuery2 Method for a Business Component
Returns a set of business component records. Allows you to control the number of records Siebel CRM returns.
buscomp.ExecuteQuery2(cursorMode As Integer,ignoreMaxCursorSize As Integer) As Boolean
FirstRecord Method for a Business Component
Moves the record pointer to the first record in a business component, making that record the current record.
Dim bIsRecord as Boolean
bIsRecord = busComp.FirstRecord
GetFieldValue Method for a Business Component
Returns the value of a field from the current record of a business component.
Dim sValue as String
sValue = busComp.GetFieldValue(FieldName as String)
GetFormattedFieldValue Method for a Business Component
Returns a field value that is in the same format that the Siebel client uses.
sValue = busComp.GetFormattedFieldValue
GetLastErrCode Method for a Business Component
Returns the error code for the error that Siebel CRM logged most recently.
Dim errCode As Integer
Dim SiebApp as SiebelDataControl
errCode=siebApp.GetLastErrCode
GetLastErrText Method for an Application
Returns the text message for the error that Siebel CRM logged most recently.
Dim sErr as String
sErr = busComp.GetLastErrText
GetMultipleFieldValues Method for a Business Component
Returns a value for each field specified in a property set.
busComp.GetMultipleFieldValues
(oFieldNames as SiebelPropertySet, oFieldValues as SiebelPropertySet)
GetMVGBusComp Method for a Business Component
Returns the multivalue group business component that is associated a business component field.
Dim mVGBusComp as SiebelBusComp
set mVGBusComp = busComp.GetMVGBusComp(FieldName as String)
GetNamedSearch Method for a Business Component
Returns the name of a search specification.
sValue = busComp.GetNamedSearch(SearchName as String)
GetPicklistBusComp Method for a Business Component
Returns the name of the pick business component that is associated with a field in the current business component.
Dim pickBusComp as SiebelBusComp
Set pickBusComp = busComp.GetPicklistBusComp(Field-Name as String)
GetSearchExpr Method for a Business Component
Returns the current search expression that is defined for a business component.
Dim sExpr as String
sExpr = busComp.GetSearchExpr
GetSearchSpec Method for a Business Component
Returns the search specification that is defined for a business component.
Dim sSpec as String
sSpec = busComp.GetSearchSpec(FieldName as String)
GetUserProperty Method for a Business Component
Returns the value of a user property.
Dim retStr as String
retStr = buscomp.GetUserProperty(prop As String) As String
GetViewMode Method for a Business Component
Returns the visibility mode for a business component.
Dim iMode as Integer
iMode = busComp.GetViewMode
InvokeMethod Method for a Business Component
Calls a method.
Dim sReturn as String
sReturn = busComp.InvokeMethod(methodName as String, methArg1, methArg2, methArgN as String or StringArray)
LastRecord Method for a Business Component
Moves the record pointer to the last record in a business component.
Dim bReturn as Boolean
bReturn = busComp.LastRecord
Name Method for a Business Component
Returns the name of a business component.
Dim sName as String
sName = busComp.Name
NewRecord Method for a Business Component
Adds a new record to a business component.
busComp.NewRecord(whereIndicator as Integer)
NextRecord Method for a Business Component
Moves the record pointer to the next record in a business component, making that record the current record.
bReturn = busComp.NextRecord
ParentBusComp Method for a Business Component
Returns the name of a parent business component.
Dim parentBusComp as SiebelBusComp
Set parentBusComp = busComp.ParentBusComp
Pick Method for a Business Component
Places the currently chosen record in a pick business component into the appropriate fields of the parent business component.
busComp.Pick
PreviousRecord Method for a Business Component
Moves the record pointer to the previous record in a business component, making that record the current record.
bReturn = busComp.PreviousRecord
RefineQuery Method for a Business Component
Refines a query.
busComp.RefineQuery
SetFieldValue Method for a Business Component
Sets a new value in a field in the current record of a business component.
busComp.SetFieldValue(FieldName as String, FieldValue as String)
SetFormattedFieldValue Method for a Business Component
Sets a new value in a field in the current record of a business component. It accepts the field value in the current local format.
busComp.SetFormattedFieldValue(FieldName as String, FieldValue as String)
SetMultipleFieldValues Method for a Business Component
Sets new values in the fields of the current record of a business component.
busComp.SetMultipleFieldValues
SetNamedSearch Method for a Business Component
Sets a named search specification on a business component.
busComp.SetNameSearch(searchName as String, searchSpec as String)
SetSearchExpr Method for a Business Component
Sets a search expression for a business component.
busComp.SetSearchExpr(searchSpec as String)
SetSearchSpec Method for a Business Component
Sets the search specification for a business component.
busComp.SetSearchSpec(FieldName as String, searchSpec as String)
SetSortSpec Method for a Business Component
Sets the sort specification for a business component.
busComp.SetSortSpec(sortSpec as String)
SetUserProperty Method for a Business Component
Sets the value of a named user property.
buscomp.SetUserProperty(property-Name as String, newValue as String)
SetViewMode Method for a Business Component
Sets the visibility type for a business component.
Dim boolVal as Boolean
boolVal = buscomp.SetViewMode(mode As Integer)
UndoRecord Method for a Business Component
Reverses any unsaved modifications made to the record.
busComp.UndoRecord
WriteRecord Method for a Business Component
Saves to the Siebel database any modifications made to the current record.
busComp.WriteRecord
Siebel Object Interfaces Reference Copyright © 2014, Oracle and/or its affiliates. All rights reserved. Legal Notices.
