Siebel Object Interfaces Reference > Mobile Web Client Automation Server Quick Reference > Object Interfaces Reference >
Application Methods for the Mobile Web Client Automation Server
Table 150 describes a summary of application methods you can use with the Mobile Web Client Automation Server. It does not include object interface methods that Siebel CRM does not call directly from an application instance. For information about methods that Siebel CRM calls with the InvokeMethod method on an application, see LoadObjects Method for an Application.
Table 150. Summary of Application Methods for the Mobile Web Client Automation Server
Method
Description
Format
ActiveBusObject Method for an Application
Returns the name of the business object that the active view references.
Dim application as SiebelWebApplication
Dim busObject as SiebelBusObject
Set busObject = application.ActiveBusObject
ActiveViewName Method for an Application
Returns the name of the active view.
Dim sView as String
sView = application.ActiveViewName
CurrencyCode Method for an Application
Returns the currency code that is associated with the division of the user position.
Dim sCur as String
sCur = Application.CurrencyCode
EnableExceptions Method for an Application
Enables or disables native COM error handling.
application.EnableExceptions(bEnable as Boolean)
GetBusObject Method for an Application
Creates a new instance of a business object.
set busObject = application.GetBusObject(busobjName as String)
GetLastErrCode Method for an Application
Returns the error code for the error that Siebel CRM logged most recently.
Dim iErr as Integer
iErr = application.GetLastErrCode
GetLastErrText Method for an Application
Returns the text message for the error that Siebel CRM logged most recently.
Dim sText as String
sText = application.GetLastErrText
GetProfileAttr Method for an Application
Returns the name of an attribute in a user profile.
Dim profValue as String
profValue = application.GetProfileAttr(profName as String)
GetService Method for an Application
Locates a business service. If this business service is not already running, then Siebel CRM starts it.
Dim oService as SiebelService
set oService = Application.GetService(serviceName as String)
GetSharedGlobal Method for an Application
Returns the shared global variables.
Dim name as String
name = application.GetSharedGlobal (sName as String)
InvokeMethod Method for an Application
Calls a method.
application.InvokeMethod(methodName as String, methArg1, methArg2, methArgN as String or StringArray)
Login Method for an Application
Allows external applications to log in to the Mobile Web Client Automation Server.
Dim sErr as String
sErr = application.Login(connectString as String, userName as String, password as String)
LoginId Method for an Application
Returns the login ID of the user who started the Siebel application.
Dim sID as string
sID = application.LoginId
LoginName Method for an Application
Returns the login name of the user who started the Siebel application.
Dim sUser as String
sUser = application.LoginName
Logoff Method for an Application
Disconnects the Siebel client from the Siebel Server.
Dim status as Boolean
Status = application.Logoff
NewPropertySet Method for an Application
Creates a new property set.
Dim propset As SiebelPropertySet
set propset = application.NewPropertySet
PositionId Method for an Application
Returns the position ID of the user position.
Dim sRow as String
sRow = application.PositionId
PositionName Method for an Application
Returns the name of the current user position.
Dim sPosition as String
sPosition = application.PositionName
SetPositionId Method for an Application
Sets the active position to a Position ID.
Dim posId as String
status = application.SetPositionId(posId)
SetPositionName Method for an Application
Sets the active position to a position name.
Dim posName as String
status = application.SetPositionName(posName)
SetProfileAttr Method for an Application
Personalization uses this method to set a value for an attribute in a user profile.
Dim oApplication as SiebelWebApplication
Dim bool as Boolean
bool = oApplication.SetProfileAttr(name as String, value as String)
SetSharedGlobal Method for an Application
Sets a shared global variable.
Dim bool as Boolean
bool = application.SetSharedGlobal(varName as String, value as String)
Trace Method for an Application
Appends a message to the trace file.
application.Trace(message as String)
TraceOff Method for an Application
Turns off tracing.
Dim bool as Boolean
bool = application.TraceOff
TraceOn Method for an Application
Turns on tracing.
Dim bool as Boolean
bool = application.TraceOn(filename as String, type as String, Selection as String)
Siebel Object Interfaces Reference Copyright © 2014, Oracle and/or its affiliates. All rights reserved. Legal Notices.
