Siebel Object Interfaces Reference > Mobile Web Client Automation Server Quick Reference > Object Interfaces Reference >
Property Set Methods for the Mobile Web Client Automation Server
Table 154 describes a summary of the property set methods you can use with the Mobile Web Client Automation Server.
Table 154. Summary of Property Set Methods for the Mobile Web Client Automation Server
Method
Description
Format
AddChild Method for a Property Set
Adds child property sets to a property set.
Dim oPropSet as SiebelPropertyset
oPropSet.AddChild(childObject as SiebelPropertySet)
Copy Method for a Property Set
Returns a copy of a property set.
Dim oPropSet1 as SiebelPropertyset
Dim oPropSet2 as SiebelPropertyset
set oPropSet2 = oPropSet1.Copy
GetChild Method for a Property Set
Returns a child property set of a property set.
Dim oPropSet as SiebelPropertySet
Dim childPropSet as SiebelPropertySet
set childPropSet = oPropSet.GetChild(index as Long)
GetChildCount Method for a Property Set
Returns the number of child property sets that exist for a parent property set.
Dim iCount as Long
iCount = oPropSet.GetChildCount
GetFirstProperty Method for a Property Set
Returns the name of the first property in a property set.
Dim sPropName as String
sPropName = oPropSet.GetFirstProperty
GetLastErrCode Method for a Property Set
Returns the error code for the error that Siebel CRM logged most recently.
Dim iErr as Integer
iErr = oPropSet.GetLastErrCode
GetLastErrText Method for a Property Set
Returns the text message for the error that Siebel CRM logged most recently.
Dim sValue as String
sValue = oPropSet.GetLastErrText
GetNextProperty Method for a Property Set
Returns the name of the next property in a property set.
sPropName = oPropSet.GetNextProperty
GetProperty Method for a Property Set
Returns the value of a property.
Dim sPropVal as String
sPropVal = oPropSet.GetProperty(propName as String)
GetPropertyCount Method for a Property Set
Returns the number of properties that exist in the current level in the hierarchy.
Dim lCount as Long
lCount = oPropSet.GetPropertyCount
GetType Method for a Property Set
Returns the value of the type attribute of a property set.
Dim sTypeVal as String
sTypeVal = oPropSet.GetType
GetValue Method for a Property Set
Returns the value of the value attribute of a property set.
Dim sValVal as String
sValVal = oPropSet.GetValue
InsertChildAt Method for a Property Set
Inserts a child property set in a parent property set at a specific location.
oPropSet.InsertChildAt(childObject as SiebelPropertySet, index as Long)
PropertyExists Method for a Property Set
Returns a Boolean value that indicates if the property that the argument identifies exists.
Dim bool as Boolean
bool = oPropSet.PropertyExists(propName as String)
RemoveChild Method for a Property Set
Removes a child property set from a parent property set.
oPropSet.RemoveChild(index as Long)
RemoveProperty Method for a Property Set
Removes a property from a property set.
oPropSet.RemoveProperty(propName as String)
Reset Method for a Property Set
Removes every property and child property set from a property set.
oPropSet.Reset
SetProperty Method for a Property Set
Sets a value in the property of a property set.
oPropSet.SetProperty(propName as String, propValue as String)
SetType Method for a Property Set
Sets the value for the type attribute of a property set.
oPropSet.SetType(value as String)
SetValue Method for a Property Set
Sets the value for the value attribute of a property set.
oPropSet.SetValue(value as String)
Siebel Object Interfaces Reference Copyright © 2014, Oracle and/or its affiliates. All rights reserved. Legal Notices.
