Siebel Product Administration Guide > Products with Attributes > Changing the Hidden or Required Settings for a Product AttributeWhen you define an attribute at the class level, you can set the attribute to be hidden or required:
Attribute definitions propagate automatically to all the products that belong to the product class. However, you can change the Hidden flag and the Required flag settings for an attribute at the product level. This lets you manage the hidden or required settings for attributes product by product. You can use the hidden setting to simplify your product class system. For example, if a product class has 8 attributes and a product has 7 of these attributes, you can put the product in this class and hide the eighth attribute. You do not have to create a special subclass with 7 attributes for the product. To change the hidden or required settings for attributes of a product
To change the hidden or required settings for attributes of a product class
| Siebel Product Administration Guide | Copyright © 2014, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
