| Siebel Product Administration Guide > Siebel Configurator API Reference > Instance APIs for the Complex Object Manager > GetInstance Method
 This method gets the loaded instance as a property set. It returns the full structure of products and attributes. Input Arguments
ObjId. The unique identifier of the complex object root.
RootId. The unique identifier of the complex object root.
(Optional) Version. Version arguments are used only when testing a customizable product version that is different from the currently released version.
 Output Arguments The entire property set output is the complex object instance. |
