| Siebel Product Administration Guide > Siebel Configurator API Reference > Instance APIs to Set Product and Attribute Values > AddItem Method
 This method adds an item to a specified port, creating a new instance of an item. If you want to change the quantity of an existing instance of an item, use SetItemQuantity. Input Arguments
ObjId. The unique identifier of the complex object header.
RootId. The unique identifier of the complex object root.
(Optional) Version. Version arguments are used only when testing a customizable product version that is different from the currently released version.
(Optional) AutoResolve. Automatically resolves port cardinality violations. The default is N.
Prod Item Id. Product Id. This is S_ISS_SUB_OBJ.SUB_OBJ_ID (in other words CFG_MODEL_ID of referred product).
Name. The name of the item.
Product Id. The product id in S_PROD_INT table.
Port Item Id. Port or domain information. This is:
S_ISS_SUB_OBJ.PAR_REL_ID if this field is not null. Port has type Domain of class or dynamic class relationships
S_ISS_SUB_OBJ.ORIG_ID if S_ISS_SUB_OBJ.PAR_REL_ID is null. Port has type Product (S_ISS_SUB_OBJ.SUB_OBJ_TYPE_CD = Product)
Quantity. The item quantity.
List Price. The item list price from Pricing Manager, which can be empty.
Current Price. The current price from Pricing Manager, which can be empty.
Parent Path. The path is the object's Integration ID of the Parent Line Item where this additem call will be acted on.
 Output Arguments None. |
