| Siebel Product Administration Guide > Siebel Configurator API Reference > Instance APIs to Set Product and Attribute Values > SetAttribute Method
 This method sets the value of an item's attribute. Input Arguments
ObjId. The unique identifier of the complex object root.
RootId. The unique identifier of the complex object root.
(Optional) Version. Version arguments are used only when testing a customizable product version that is different from the currently released version.
Path. The path of the item with attribute to set.
Value. The attribute value.
Name. The attribute name.
XA Id. The extended attribute ID. This is the row ID of the attribute in the XA Attribute business component. This parameter is required, and you can use a dummy value instead of the actual row ID.
Property Type Code. The attribute type.
 Output Arguments None. |
