| Siebel Product Administration Guide > Siebel Configurator API Reference > Instance APIs for the Complex Object Manager > CreateSession Method
 This method initializes a configuration session, which is necessary for products with components that have constraint rules. It is called immediately following LoadInstance where required. Input Arguments
ObjId. The unique identifier of the complex object header (for example, Quote Id).
RootId. The unique identifier of the complex object root (for example, Quote Line Item row id).
IntObjName. The name of the integration object specified in Oracle's Siebel Tools.
TriggerEvent. The flag that determines if script events are triggered. Normally, it must be set to Y. Set to N for special uses of the API where script events are not desired. LoadInstance and CreateSession must have the same setting.
(Optional) Version. Version arguments are used only when testing a customizable product version that is different from the currently released version.
(Optional) NewRecord. If set to Y, the instance will be populated with default values. The default is N.
(Optional) AutoSync. If set to Y, the instance will be synchronized to the database immediately after loading. The default is N.
(Optional) ExternalScript. This parameter must be set to Y when running headless configurations (for example, through Siebel COM Data Server). The default is N.
 Output Arguments If NewRecord is set to Y in the input property, the output will have the instance property set returned as a child of type CxObj. This is essentially the same output as the one that is returned from GetInstance. |
